*ouch* >< Okay - my turn to fess' up:
+ Drilling the holes through the grill (to let more air into the stock airbox where it was blocked by the grill) i let the spinning part of the drill head touch the grill - bzzzt! Ate it UP!
+ Didn't torque the oil pan bolt once - leaked - but i noticed and re-torqued.
+ Used 600grit/wetsand to 'smooth the dings and scratches'. Looks like @ss. I will re-attack again (with more success?)
+ Cut the power wires this [ ] short to fuse block. Dang! Kinda' half-@ss hung in there. Do the fuses match the componenets? I dunno'... ><
+ Didn't get the timing cover completely on - the noise stopped eventually after the UDP wore it away...
+ Didn't securely fasten the kayak to the roof - big wind gust blew it down and it broke the side view mirror and gashed the side....
+ Couldn't rig the throttle cable after doing the throttlebody thermal spacer - had to take it back off (re-install the intake manifold without the spacer too).
+ Didn't torque down the rear strut top nut - banged and rattled until i stripped the car down and re-torqued it (installed!)
+ Installed lowering springs (see above) but didn't replace the struts at the same time. Turned around and did the whole job again to install new struts 5K miles later.
+ Put the speaker crossovers inside the door panel (too hard to feed the wires and too lazy to pick up the wires at the radio) - so corrosion takes it's toll.
+ Didn't bolt the radio in - it kinda' stayed all by itself. Until i hit the big bump and it fell out and dangled by the wires. Gimp!
+ 'Stretched' the MAF wires to fit my ghetto-rigged el cheapo handmade SRI. The wires eventually wore and the stumbling/stalling became intermittent. Soldered in a new section - like i should have - good to go!
+ Same ghetto-install (see above) didn't really hold the MAF and filter well - fell off doing a squirrely burn out. Stalled out. dork.
(This is all i will admit to!)
