stripped my intake box bolt holes
black_ninja23
Mazdaspeed 3
can any suggest what I can do to fix the stripped bolt hole for the MAF sensor. I was cleaning my intake, and decided to remove the MAF...when i re-installed it one of the bolts stripped the hole. any advice is appreciated.
Better idea... Buy an aftermarket intake !! Pick one, they all do the same s*** ! That will fix your problem and add some power !
You could fill the hole with some plastic epoxy as well then when its dry run the screw through it, should makes its own threads.
Why not do it right? Take the stock bolt to a hardware or tool store, get the correct size tap and run it through the buggered threads. Presto, fixo.
+1 on epoxy. Fill the hole, let it sit, then rethread = new plastic threads
dab of jb weld or equiv in hole run screw in and out to distribute. let sit for a bit to get partial cure. clean screw very well, and put a drop of oil on it, straight from the dipstick is nice.
thread it in to just barely snug and backout a skosh. let cure fully and snug down
