Storage Bin
yes, constantly...if you put pressure on it with your hand, it stops...not so much the door of the compartment, but the frame. (putting pressure on the back of the compartment works best) so if you want to fix it, I guess you could stuff some stuff around it to tighten the fit. Some shims or something...annoys the hell out of me, not as bad as the passenger side lower kick panel though. I can hear that always!
i don't get any nise at all but then again my hole dashboard was replaced from when they stole my radio, damn bastards!
by the way it took me 8 months to get the radio from the dealer
I have an ES, and I changed my rims to 17x7 with 215/40/17.
This is probably the reason of the noise. It isn't that bad though.
it might be, but maybe you wanna look into a better suspension or at least part of it, if that's was cousing the noise, but maybe is just something loose
