Stock Wheel info
DRKNYTE
2008 MAZDASPEED 3 (BLACK MICA)
Can anyone provide the stock wheel info:
Bolt Pattern -
Hub Bore -
Lug-nut pitch -
Width -
Offset -
Weight -
Tire size -
Thank you!
Maybe make it a sticky? Maybe?
stock wheel info:
Bolt Pattern - 5 x114.3 mm
Hub Bore - 67.1 mm
Lug-nut pitch - 12x1.5 (I believe)
Width - 7"
Offset - et52.5 (I beleive)
Weight - (~22-24 lbs - not 100% sure about that, info is second-hand)
Tire size - (stock) 215/45/R18
