doctorz said:We added a cassette player to our 5 (you can indeed get it in the US) and have tried two solutions to getting the iPod to play.
The iTrip (FM transmitter), which worked fine in our MPV, doesn't work great in the 5--it works reasonably well in rural areas if someone's holding the iPod, not so well in urban areas, and we have to switch the frequency about every 20 miles to avoid static.
We tried the Monster cassette adapter and the sound output is minimal. If both the iPod and the receiver's volumes are turned to max, you can barely hear the music, and that's with the car at idle. We didn't even try it with the car at highway speeds. The reviews of cassette adapters I've seen say that this can happen and depends on the car and the cassette adapter. Sometimes it doesn't even work at all.
Thoughts? What cassette adapter works well?
EFDisaster said:FM Transmitters kinda suck, and I've had the least amount of luck with them in the 5 than any other kind of car... the tape deck was a good investment. I got it, too. My cassette adapter is an old Sony, and the volume is just fine. I'm also using a Belkin power adapter that has an audio jack on it, so I'm using the fixed volume from the iPod and not the variable one from the headphone jack... no problems with being loud enough.
I've got the whole thing mounted on a crazy bendy mount from Best Buy that's supposed to stick to your windshield, but I stuck it on a spot just big enough, next to the shift knob (and bent it so my hand wouldn't hit it when shifting to park). I'll post some pics. The only person who didn't like it was the passenger who wanted to cross their left leg and put their knee where the iPod is... so I dumped her and got a new girlfriend who sits normally (evil)
It wouldn't let me upload the pictures... but they're on this page:
http://fashiondisaster.org/v/misc/?g2_page=3
direct links:
http://www.fashiondisaster.org/g2/d/2147-1/P9060013.JPG
http://www.fashiondisaster.org/g2/d/2150-1/P9060012.JPG
P_bouchr said:@Doctorz
Seems that when it comes to cassette adapter, cheaper is better, remeber that. I tried the griffin smart deck woth no luck. The cheapo one I have still gives me good results after 3-4 years of use. Set ipod to 75% volume and you get approximately the same output as CD or radio. Plus bass booster on the ipod gives the mazda system sound what it lacks in bass.
We&2kids said:My question to P_bouchr: when you said you had "no luck" with SmartDeck, did you try it with your Mazda5? If so, what was the problem? In my Audi, the cassette deck just ejects the adapter after a few seconds. When the adapter (SmartDeck) is inserted into the deck, it does activate the iPod (turns it on in pause mode) for 5 seconds or so, before it is ejected. Did you have the same experience?
Kid Red said:Mazda will (hopefully) be releasing their Apple certified iPod connection device soon for the 2007 models. It will work with 2006 models and is slated to cost $150. THe iPod will be disabled and you can use your steering wheel controls.
So hold off on any huge expensive foray into such a solution.
Found this recently:
http://www.axxessinterface.com/default.aspx
There are 2 models for the Mazda 5 that work. Apparently for the Axxess XIA-I01 you have to buy a separate adapter but it allows you to use the steering wheel controls with the iPod. I personally am interested in the Axxess MZ-AUX-01 as it will be cheaper and not require any special adapters to work. I spoke with someone at Metra Electronics (the manufacturer) and they assure me that the Axxess MZ-AUX-01 is slated for manufacture in about 3 weeks. It has BOTH a power/audio port for the iPod AND a standard audio input on a nice little box that can be mounted out of sight and plugs directly into the back of the OEM stereo. I first saw these units for other vehicles at Circuit City a few days ago. They ran between $49.99 and $69.99.
