Stock pipe or not?
schlepperock
07 ms3
The pipe from the turbo on my car appears to be painted the same color as my car. Is this stock? It's black with a metal flake. I bought the car used, so I have mo idea what has been done/undone. There is a turbo timer on it. And screw holes in the steering column, I'm guessing gauges were there.
So I should get a Sri instead or a full cai? Is there a difference?
it's just the inlet pipe so you can get an sri or cai. they both attach to the inlet. if price isn't an issue then i'd suggest a cai. people say it doesn't matter and cai's are a waste of money because the turbo heats up the air anyway, but i disagree because the cooler you can make the intake air charge, the less stress on your turbo
I thought the cai would replace this, Wich being an aftermarket pipe I figured I should keep it. Your saying a full cai bolts to this pipe?
no the cai goes downward, usually in front of the front driver side wheel
the sri's end at the stock airbox location
Enjoy it! Lucky bastard! lol, that's one of the few things remaining I need to be fully bolted!
