Ok man, I just didn't want to relive the 'my engine is going to fall out' paranoia that spreads around here sometimes![]()
I hold boost fine with the blue spring.
Just because 1 or 2 people's stock bpv isn't holding boost doesn't mean all of them are leaking. Wouldn't hurt to test your own but it doesn't mean everyone's isn't holding proper boost levels.
Forgive me for this noob question: If the stock bpv is crappy would that play a part in our brutal lag during upshifts? I know a turbo engine will bleed off boost when the throttle's lifted, but other turbo cars I've driven haven't felt nearly as bad. Isn't the bpv supposed to vent the intake backpressure when the throttle's closed to let the turbo freewheel and build pressure quickly when the throttle's reopened after a shift? I refuse to flat-shift as it's so hard on the drivetrain and I like letting the revs match for (mostly) smooth upshifts even when I'm charging through the gears.
Any time you lift of the throttle your bpv/bov which ever you desire should bleed of un-used boost (into the intake or atmosphere depending on the system you run) stopping evil compressor surge. Using a more aggressive bpv with a stiffer spring may help close the system up more efficiently keeping some of that hard earned boost for the next gearI've noticed this too! I hope someone addresses this question.
