I know this topic has been gone over Thoroughly about three times a week, but I need help. So I went to the dealership and got the ECU reflash. I thought it was fixed but...
I had a small oil leak from the oil cooler gasket and I fixed that along with removing the gasket and replacing it, and removing the oil sender and putting some thread lock on it to get rid of the leak. After this, I found that I was experiencing a stumble in every gear after first only when the engine is warm, and only when entering boost between ~2500-4200 rpms. If I boost over 4200 rpms, it boosts just fine. If I start boosting in the problematic RPM range, then I get a hesitation. The car sounds like it is boosting, but the boost does not increase the engine speed,and the car does not seem to go anywhere and "boggs". I dont have a boost gauge tho, so I cannot confirm this. Also after the engine warms up, the car will die if I am driving and put the car in neutral and/or engage the clutch to cruise in neutral. It also idles rough and jumps between 200-700 rpms idle when stopped, and consistently acts like it is about to die. Any ideas and info would be greatly appreciated.
Oh, and I am running a parking break sensor code but that is it...
