k so excuse me if i sound retarted lol but wat ur tryin to say is to mix it first??? or just to squeeze the gel into the mount and let it sit tthere?
what i did was exactly like this..
took the motormount off... taped the buttom part with clear thick paking tape... squezed the 2 bottles of epoxy gel inside and i let it sit for the longest time.. then when it sarted dripping out after an hour or two i tried taping it more and it kept dripping out. i left it alone and still havent looked at it... who know if it dried up or not...
Yes, you must thoroughly mix the epoxy first before putting it in the mount. I suspected this might be the problem from your description. You might as well get some acetone or methylene chloride and try to clean the mount up because it will never cure as is. Your not retarded, just at the low end of the learning curve for this particular process. Everyone makes mistakes while learning. One of my suppliers was making a fixture to hold a passenger airbag cover. His mold failed and he dumped 3 gallons of mixed 94A urethane on the floor. That's $180 per gallon......and a helluva mess!
-enganear
