levison said:i like the sti gold wheels and was wondering if anyone knew if they fit the msp? thanks
shane02pro5 said:8" wheel with 53mm offset would hit your strut.
shane02pro5 said:I have 18x7.5's with 50mm offset on my P5 which has less fender clearance than the sedans do in the rear. I have around .200" clearance to my fender and .200" clearance to my coilovers. With 53mm that will give too much tuck. Possibly with some very thin wheel spacers to pull you back out away from the strut. Try a search for "18x8" fitment I know there have been problems.
neither. i told you i suck at explaining. i ment the way the tire is on the wheel, the way the sidewall curves. heres an exagerated jpeg to kinds show what i mean. in the STi's case the tire width was not changed but the wheel was so it would cause the tire to feel stiffer but not change the amount of grip. i think that explains it a bit better.mountjonas said:camber, or toe?
