smp3000 said:right, but in theory advancing the timing under low rpm and in "non" boost states would raise the idle right?
That is correct.
This is a silly one... but check it anyway in case the place messed up during the install on your car... make sure the MAF isn't pointed backwards... I would think you would have more problems... but it is a simple check at the least! Also try to verify that the vacuum hoses are going to the right locations as well... not that they are just not leaking.
Really hope you get it straightened out soon!
Later.
Steve
