Srt4 plug wires.... Sooo close!
2001 Mazda Protege MP3
So I got bored the other day and grabbed some extra srt wires that were sitting around to see if they would fit on the mp3. With a little rigging, they come really close. I think the car did feel smoother but maybe its just me
Our stock ones just seem so thin. I can tell by looking at them the difference in size. I've just always liked running thicker wires on my cars.
Did you snap the bolts that hold the coil packs? Your major worry now is condensation/water getting in through the holes.
From my understanding the thicker wire takes longer to get spark through which ends up being worse
Bigger the wire, the more amps can flow through. However, the waste spark system used in the protege is a low amp system. .5 amp at 20-30,000 volts.
Yup. Gnerally, "bigger" wires are just heavily insulated to protect from heat, corrosion and metal it can ground to.
