Squeaking Noise From Suspension When Passing Over A Bump
If your 5 is still under warranty, it's covered. See if they'll try some sort of winterized lube spray on it if you get it done.
bump. My '03 6 has horrible squeaking in the front when cold. The dealer has looked at it twice and both times did not recommend any replacement of suspension parts. When the temps are 50 degrees or more, no squeaking. Car sounds like an old pickup. Definitely interested in any recommendations for lubricating bushings.
