Mods - Please Sticky as people with any type of sputter needs to check this first before they try other things. Specially those with minimal mods that get this sputter as I can pretty much guarantee its their issue.
The problem is the Turbo Inlet Hose connection. Check it to ensure the clamp is properly tight. I have been getting sputter from time to time and then really bad when I installed the MBC and turned up the boost. Today I checked my Inlet Clamp and to my surprise it was so lose I was able to do about 20 turns before it felt tight.
The Inlet Connections all need to be checked and ensure they are tight. To get to it you will need to remove the TMIC reach behind with a socket to tighten the connection.
After I tightened mine I took her for a spin. No Sputter at all in 3rd anymore and it pulled all the way to redline!!!!!!
I did get some sputter in 4th but in my case that is Fuel cut as my HI FLOW PSI dropped to 900PSI. However those with minimal mods and no MBC/SB should NOT be getting sputter and I would bet the reason you are is due to the Inlet Connection being lose.
To me this should be the very first thing you check if you think your car is sputtering or not pulling as hard as you would like. My turbo spools much quicker now and I swear I can pull all the way to redline without feeling like the car just dies HP wise.
I hope this helps.
I hope this helps.
