sprint springs
mp5420
hey quick question i just got my sprint lowering springs 2 inch drop what camber kit should i use if any and is the the drop to much for a daily driver in boston thanks in advance
2" drop + snow = bad idea
and check the spring rate, if you like hard driving, they gotta be STIFF.
I had Sprints on my car for 6 months, installed them in January '04. Didn't need a camber kit, but my car hated curbs w/ them, they are also fairly soft springs. But they do give a flat drop on the P5, which looks nice.
I had sprint springs on my p5 for a couple of months now and the rear seems to be sitting higher than the front, since you mentionned sprint's give a flat drop(what I thought it was supposed to) can somebody tell me what could be wrong?thx
double check that the springs are seated correctly on the rubber seats on the stuts
lav_s said:
Is it possible that they've rotated once seated?
I would think so.. ex. like if you jack the car up.
I have the sprints on my car. They do give it a flat even drop and I got my car aligned without needing a camber kit.
did you change the endlinks?
