SplitSecond AFC Map question
oh3speed
Mazdaspeed Protege
I don't know too much about the maps for this, but I am going to put it on my car in a few days. All my car has is a CAI, so should I leave the map that comes on the AFC? Or should I use the superstock map? My car was factory flashed if that makes a difference. What advantages does the superstock map have if it is recommended.
Any info helps. Thanks
The AFC comes with the supermap already loaded, and that will probably be the best one to use.
Do you have a wideband?
+1 use the stock supermap. It does good enough for now, and you really dont have any mods so i wouldnt worry about it. Also on a side note: Dont even think about tuning your car w/o a wideband.
