Speedometer fix to read correctly, is there one?
ToRcH
Mazda MX6
Okay so I've searched till my eyes bled. I just put 215/45R17's on my car. Now since the MSP runs this identical set up what is the difference that lets the MSP read the correct speed but the ES to read 3 mph slower?
So my results show that the signal comes from the two from ABS sensors. So since I don't believe mazda put different size ring gears on the hubs and sensors on the MSP that leaves either the ECU or a speed sensor in the tranny. The auto tranny in my ES has a dummy plug and rock auto is showing part#'s for the speed sensor.
I just want my speedo to read right because i'm going to forget one day to do the math and get pulled, and I want my OD to ready right too!
Any ideas or help would be greatly appreciated!
If your car has ABS it runs off the ABS sensors, otherwise it is the speedo gear in the trans.
