TX Speed 6
- Mazdaspeed 6
(bowdown) can't wait to see you take it out to the track after the TMIC intall!!!!!
AFR at WOT 12.4/1 boost 17-18psi(15.6stock) timing retarded down low and advanced up top...want to know more? Gotta ask Ken.(headbang)RevLimitLaunch said:is the 13.1 with the xede fully tuned or just playing around 'safely'?? im not too sure if you already posted it but what was the boost and a/f r's at?? 7/10 of a second is crazy!!! awesome job though.
RevLimitLaunch said:damn thats a pretty high afr no?
StephanieT said:An AFR of 12.5 is normal on a turbo application. The disi's can run a little leaner than that. I probably would not go any higher than 13.0 without some race gas or E85.
Stephanie
RevLimitLaunch said:eh i guess i kind of forgot about disi in this case...i've always heard that a 12:1 is pretty aggressive on a turbo car, but those were regular non disi motors...
93vert said:This might have been asked, but what octane level did you use during the 1/4 and what octane should be used for the base map of the xede.
Captain KRM P5 said:i don't know if i'd put ethanol in a standard fuel vehicle as over time it could corrode the fuel lines and clog your filtration systems. the octane level is however higher than normal gas. just my .02
Rican219 said:What in the world ran that time on your best time slip?
Kooldino said:Badass. Congrats!
Kudos to PG for the great work.
