speed sensor wire
AZN2NR
anyone knows where the speed sensor wire is locate for the ms3? I had a turbo timer installed but could not find the speed sensor wire so I can hook it up to use the other features such at track time,0-60 time etc. Any help is appreciated.
good luck, I'm still trying to figure it out. Post if you find it first.
I know its green/red in harness behind radio in mazda 6 could be the same location but Im not sure.
IIRC there is no vss wire unless you have factory nav. If you don't then you have dp some kind of add-a-pin type thing somewhere. search a bit around here.
