Jdizzle659
- Mazdaspeed 3
So I have an 07 mazdaspeed 3 with dp, rp, cat-back, intake, inlet pipe, trans mount, rear engine mount, ap, and now the spec stage 3+ clutch with the fidanza flywheel. My 40-100mph times before the clutch and flywheel installation was at 7.4seconds on my best run before slipping. A bad run i did with the clutch slipping at high boost was 7.8seconds. Now I can't even get close to getting it under 8 seconds. Did 3 runs all above 8.3 seconds. Nothing else on my car is different only the clutch and flywheel. I can't figure out why it would be so much slower... Before doing the runs I had 635 miles on the new clutch. Never got on it during that time so the clutch is broken in properly. Any ideas???
