I am in the process of running new wires to all my speakers because (in addition to deciding on an aftermarket amplifier in the trunk) somewhere along the way my stock wiring started corroding or something and one by one i started to sporadically lose power to my speakers. i checked all the connections at the head unit, re-soldering and testing each wire in the harness that connects my aftermarket head unit to the stock harness and even tried using the stock head unit to no avail.
The rear speakers were easy to do, as the connector that supplies all the wiring to the rear doors had two empty spots that i drilled out and ran the wires through (like i saw on another post here but i cant seem to find at the moment)
However the front ones connect under the dash and don't have enough room to get a drill in. anyone have any suggestions on where/how to run new wires to my front speakers?
