spark plug hole oil
johnpili
mazda 929
hey just replaced my spark plugs and there was oil in the hole
is it normal or something worng with it?????:'(
its a mazda 929 HD 1994
what would the seal be called exactly??
too hard with the weird manifold on top T.T
wonder if anyone installed an individual throttle bodies on these engines or is it possible?
they would be plug tunnel oil orings included in a top end gasket set, twin throttles would be good and should be possible, it may take a bit of work though.
its either your valve cover gasket or bad pistion rings (will consume a shitload of oil) id go with valve cover gasket first let me know if it helped u out :D
