Sparco Harness Bar?
ChopstickHero said:
nice!
I assume mounting points will have to be made though, unless there are specific points that can be used where the bar meets the B-pillars.
It uses the bolts where the shoulder belt hanger go.
Well I got some news. I already knew it would work ya, but I took the bar and just eyed it inside my car a couple days ago. It deff will work. But, as some of you may know, Wagner is now coming out with a bar of their own and has a GB thread on it :
http://www.msprotege.com/forum/showthread.php?t=121231&page=1&pp=15
I'm mainly waiting for all the smoke to clear in this thread (something about matty and some pipes wagner was supposed to make etc... idk/I don't care) and seeing if there will be 11+ ppl on this GB. I see no reason why there shouldn't be, since there seem to be a lot of ppl very interested in it. If the price gets down to $250, you can bet your ass I'm in on the gb, as it will save me $100 and I won't have to worry about any modification (however slight it may be) with the sparco bar. That and the Wagner bar sounds like its supports mount to the rear seat bracket mounts on the tran. hump, rather than having to cut away some carpet with the sparco bar... it's a small +, but a + none the less... not to mention it could end up a hellva lot cheaper for me. After all the BS with the matty pipes is done with, I would say jump on the GB w/me if you're interested....
*sparco project is on hold for now*
