sound! cobb tbe or borla with cobb dp
09TRMS3
I am debating on which exhaust to get out of these 2 only. I have only heard clips on the internet but cant really decide whether i want to the cobb tbe or the cobb dp/mid pipe and borla exhaust. does anyone know which sounds better. less drone and deeper is what i like. I hate loud raspy obnoxious exhausts.
Cobb pulled their cat-back off the market. Something about recession, reducing product offerings or something.
I know they pulled it off the shelf but i can still get it from other sites that still have it in stock. Im just wanting to know if the cobb or borla would be better sounding. I have heard corksport its aiiight.
No aftermarket CBE is going to build power with our stock turbo. The stock CBE flows freely for the maximum air flow our KO4 turbo can pump through the engine.
The power gains will come from the DP/RP, which is where the real restrictions are located. It is good that you are going that route. But understand, please understand, that if you are wanting to avoid drone, the DP/RP combo will definitely introduce quite a bit of drone on decel as you pass through the 2500 rpm range.
I ended up putting in a third reso in line in the RP in order to tame the drone.
My humble suggestion is to not go by sound clips on any CBE unless that setup is also running a DP/RP because the latter will definitely change the sound - louder and more drone. So be sure the clips are TBE's.
Yeah i know i wont get really any power gains but i do want a deeper sound. I know that it sounds different with dp/rp and thats what im looking for just dont know which combo would sound better. cobb with cobb dp/rp or borla with cobb dp rp
