Soooo... my NEW WHEELS showed up today! Thoughts?
looks so sick! post up pics after you put them on. Are you going to sell your Stock wheels?
Thanks =)
I plan to keep the stocks for when I sell or trade it in. Unless I get a reasonable offer, which is unlikely considering their value.
Springs still need to settle......
I should point out, theres no rubbing. Very close but rolling them wont be needed, even when settled fully.
That's impressive. I get the impression there's a bit more room under these fenders than in the 1st gen.
For those of you who requested profile pics to see the wheel and fenders.... here ya go...
REAR from above
FRONT from above
The car has only been driven 30 miles with the new H&R springs in, so its going to settle quite a bit more that what you see here.
Those are the same size tires as stock then? 225/40/18
Looks Good!
Also how do those springs feel compaired to stock so far?
from his sig... "Nitto NT 555 Extreme Performance 235/40/18"
Cool Thanks, I must be blind! I looked at his sig too! (boom03)
235's and also on an 8" wide rim. They connect to the road well. Feels more solid.
Ok, Thanks. I'm looking for springs for the track. But heard the H&R's
might not be good enough for that. But I was thinking those with
an upgraded sway bar should be ok.
Darkspeed ur car looks sick , I have a question for you , your car is sitting on a 8" wide wheel ,will i get away with a 8.5" wheel without droping the car? .keep up the gr8 mods very inspirational .
You could get away with 8.5 is the offset is right. Otherwise the tire may rub against the shock/strut
