Something is wrong with my engine...HELP!!!
get the bung and use the spark plug non fouler trick. it will kill your cell and you dont need to wire anything
what do you expect you are going from having 2 cats to having none, it is going to smell like gas a lot....you will get used to it.
there is an extra o2 bung on the car. If you still have the stock J-pipe there is a small nut on the passenger side of it. If you take that out there is a o2 bung there. Now you go get the spark plug thingy or a MIL eliminator and you do not need to get a bung welded in.
Spare Bung!
I was running down through this thread wondering when someone was going to say that!!! There is a spare bung on the right side of the J pipe!!!!!
