Silver Ecstasy
- 11 MS3 Sport
So I had a few thoughts today about our LSD that I haven't seen a single person post on here (or atleast since i've gotten my MS3).
-Tire pressure should absolutely even between the front two tires. If any tires should be monitored, it should be the front two. If you have a tire that is lower or higher than the other, you will have unequal rotation and this will cause the LSD to work overtime, causing eventual failure of the diff. The mentality is almost no different than cars with AWD systems. If you have varying tire PSI's on opposite sides of the car, that can cause damage. So..friendly reminder would be to make sure both tires have the same amount of pressure!
-Rotating or replacing tires: I thought about this today. Let's say you were to blow your front tire. So common sense would be to install the spare tire until you get to your destination. But..shouldn't you install the spare on the rear wheel instead, and swap good rear wheel to the front, until you can get safely home? I can't imagine how much damage that would cause to the LSD, forcing so much power to one side of the car for an extended period of time.
Also, if you were to replace your front tire, you should probably just replace both, or replace the one, and rotate your rear wheels to the front, and swap the front tire with the new tire to the rear?
I did not read any of this in the manual, and i'm taking what i've learned from owning a GTO, TBSS and seeing what happened to my mom's 03 Mountaineer AWD after having to replace the front diff twice and the rear diff once. She NEVER checked her pressure and we took a lot of trips in that car.
