Soft steering!!!
SpeedKnight
2007 Sunlight Silver MS3
I am planning on taking the Speed3 to the dealer soon, just wanted to ask if anyone had similar prob or what i can expect to be wrong. Steering seems soft, meaning steering wheel is turned but I am still going straight! Will turn fine but seems to delay or just take longer to respond. something has seemed loose when turning or hitting bumps but not all the time. I hit a pot hole 2 winters ago hard enough to bend the rim a bit. Steering fluid is fine, tire pressure is good, all lugs are tight. Any thoughts?
id do a visual check of all the linkages and mounts, the power steering pump, the pulley/belt system, check bushings/bearings for play. the whole system needs to be looked over.
^ Agreed. You should check to see if there is anything obvious..(could be dangerous).. Sounds like rack and pinion damage or tie rod
