- Protege5 2003
Today I was cleaning up under the hood and wiped off the top of the washer fluid reservoir's cap. Lo and behold there was a tiny hole right in the center which had previously been hidden by dirt and grime. Then it finally dawned on me what the tube attached to the washer fluid cap is for - it's a pipette! Just put your finger over the hole with the cap down, and then pull the cap and the attached tube out of the reservoir and the fluid will stay in the tube at the level it was in the reservoir, nice and easy to read. Previously I'd tried to figure out fluid level by how high the wet part was on the outside of the clear tube and that was really hard.
So I looked, and the owner's manual does explain how to use the tube, which might have been useful if I'd ever read the thing cover to cover. I mean, who the heck refers to the manual before filling the washer fluid reservoir?
