DooMer_MP3
Seeing as how my clunking is coming back (had swaybar replaced in January, started clunking a few weeks ago), I think its time to talk to the dealer again. I'm going to mention the control arms being replaced and probably print out JcsMP3's thread. I'm worried about how they will replace these... Should I make sure they remove the rims and/or not use a cutting torch? I've heard if they do that you weaken the sway bar. Can the controls be taken off by normal means (ie taking off the sway bar assembly completely)? Thanks!
