Snapped an axle.
i wanted to upgrade to mazdaspeed axles when i was getting my lsd, it was about 1000$ just for the axles.
I guess we cant use slick with stock axles......
Good luck.
GOTZOOM? said:
I was staged and ready to go when the axle snapped, light was turning green, I let the clutch go, and BAM! The car didn't even move an inch, hell, I was still staged after it broke. I usually launch at 3000 to 3500, and in case your wondering, I use BF Goodrich drag radials.
Curious, do you think the broken axle flailing around caused any damage?
The axle is pretty short, it was sticking straight out from the tranny, so all it did when it snapped was just spin in mid air, nothing for it to hit.
Thats usually the cause of most axles snapping. You are unleashing full engine torque onto the axles and if the tires don't break loose something else usually goes.
Slip the hell out of the clutch and you'll keep your axles longer.
Uhh, no, this car wasn't built for babying it down a track, I will find stronger axles somewhere.:D
If not, then it seems like I can get 10 runs out of the axles, I will just take extra's to change at the track when they break.
BTW, just for "search" purposes.
97 Probe axles are the right length, but have 2 too many splines, need 26, it had 28
00 Escort has the right amount of splines, but is 1/2 inch too short, 24 1/2 inches, need at least 25 inches.
I am trying to locate 99 Cougar axle to see what it looks like, have not found one yet. If it is the right one, ABS was standard on the 5 speed, so I will have to deal with that funky toothed wheel, but shouldn't be a problem.
Others I am looking for is the Contour and ZX2, and also looked for Kia Sportage, but it wasnt available. It is probally the exact match, and thats why its not available since the Proteges arn't.
how about the 626
sportage is rear drive
Well, I don't know if the stock axles come shot-peened, but you should get it done. It will eliminate some possible shear points.
I was looking at those pics and wondered why in the heck did they taper the axles to a skinnier diameter? Just to save a little weight?! Can they really be saving money by doing that?!
Yep, I was wondering the same thing. Thats why I really was hoping the Probe would fit. It was one diameter straight accross, and a bit thicker.
dont the probe hubs bolt up?
they should the part numbers on the brakes seem to be the same. Maybe you can just swap the knuckles
Holy s***!
I'm sorry for the bad end to the day, but to snap an axle like that, it is pretty impressive. Damn.
Best of luck with your new upgrade search. Let us know how it goes.
igdrasil said:
cant be that bad $625.
Are you sure???? :eek:
You just had NO LUCK at all. Because my axles are still there and mi friends too and hes doing 13.2-13.5 on his P5 @ 11psi with slicks and bronze clutch.
What's a bronze clutch?
the 4 puck unsprung, This one:
