SLSPERFORMANCE said:Limited time offer "DISCOUNT CODES"
Spend over $65 and get $10 off any order use code: M247-10
Spend over $90 and get $20 off any order use code: M247-20
Spend over $160 and get $30 off any order use code: M247-30
This means,
Our Front Motor Mount is only: $58
The side Motor Mount is only: $75
Mid pipes from: $109.99
J-Mid pipes from: $149.99
This is a limited time offer, and is for forum members who use the discount codes only!
So don't delay, Get yours while this offer is available!
SLSPERFORMANCE said:Discount codes are still available
amsgator said:it may need a stiffer mount in the rear though b/c the sides are done. if the sides are not supporting the engine correctly then it puts extra stress on the good mounts. and if the front is completely stiff like it is w/ an aftermarket mount then thats more movement being shifted so it breaks the threshold. i am hoping this is the problem![]()
SLSPERFORMANCE said:discount code should be on the same page as the payment option.
amsgator said:is it better, worse or same? it might be vibration from the driver's side. mine still does it tooi might have my g/f look while i start off in 1st gear to see where it's coming from and if it's the engine dipping
