- Protege
Im looking to get some slim fans but not sure which i should get i know some pull some push some do both but which is better? Also what size are you running? I heard you can fit 2 12" fans but others have used a 10" and a 12". Which brand are you using? Basically any advice on the matter is appreciated.
Id like to get these because they match my radiator but
https://www.ebay.com (commissions earned)
if these will get the job done then i can use the money saved elsewhere.
Thanks
Thanks
