- 2017 CX3 AWD
Folks, please help me get a sense of how hot we are supposed to run. My first poll ever, forgive me if I leave out your engine... Thank you!
Appreciate the info! My coolant temp is around 195 and oil 205 to 215!I didn’t do the poll since I only know my coolant temperature… but both my stock 2.5 turbos run around 200-205 Fahrenheit.
Mine is also read from the app but probably calculated/estimated. If that's what the ECU wants me to think, I have to take it seriously!How are members reading their oil temperature? I can read mine with my OBD Fusion app but I don't know if its actually reading the oil temperature or estimating it.
It depends on the car:How are members reading their oil temperature? I can read mine with my OBD Fusion app but I don't know if its actually reading the oil temperature or estimating it.
I am going by the stock gauge on the instrument cluster.What I have learned is that you have an actual oil temp to read. Are you reading your temp with an app or a device?
Post in thread 'OBD2 Scanner/App: what sensors/values to monitor?' OBD2 Scanner/App: what sensors/values to monitor?
Got it. Mine shows neither, not even a gauge that says low, normal, and high. I use an OBDII adapter to connect to my phone to read the figures from an app.I am going by the stock gauge on the instrument cluster.
