Size of front sway bar bushings? 2009 Mazda5
livewire78640
2009 Mazda 5
Need help, trying to find correct energy suspension bushings for front sway bar of a 2009 Mazda 5, are they 23mm? Are the rear ones 20mm? thanks much
Sorry about the late reply, you are correct in the sway bar bush sizes- 23mm Front and 20mm Rear.
2006-09 MazdaSpeed 3 - 26mm for F&R Sway bars
Edit: 1st Generation 2006-09 Mazdaspeed3 Front Sway Bar = 26mm , Rear =25.4mm !!!
2nd Generation 2010-on Mazdaspeed3 FSB = 26mm, Rear = 26mm as per new factory specs std
2010 Mazda 5 close to 140K miles, deal with cluck sounds when passing uneven road specially in local since 70K around just like many Mazda 5 owners. Did anyone replace swing bar bushings then noise gone? We love the car and want to keep it so we consider to do something about it.
