Sho's 7th Mazda! (2025 CX-70 Turbo Preferred)
bigsho
2025 CX-70
Hello!
Picked up a Cx70 Preferred MHEV on Monday.
Not a stranger to Mazdas as this is my 7th one.
But it is my first ever brand new car, and first car that has an automatic transmission.
Had a 2007 Mazdaspeed 3 GT. Bought in 2012 with 25k miles. Learned how to wrench, and tune with that car. Built motor, precision 5862 turbo, auxiliary port injection, coilovers, sway bars, etc. On e48 Ethanol mix, self tuned it made 575whp/467 tq.
Had 2 2006 mazdaspeed 6. One as a beater and one I went all out with during covid to show that the MZR disi was a stout engine if you knew what you were doing. I put a pte 6266, aux port injection, and all supporting mods on an untouched bone stock car. Made 539awhp/421 tq, using a reverse tapered boost curve to keep tq in check. (The accepted limit for the stock connecting rods is roughly 400tq). And tq needs to be limited below 4000rpm as well. That setup didn't eclipse 350tq at the wheels til after 4000rpm, 400tq til 5500rpm and made peak tq at 6200 rpm. Put 25k miles at that power with over 1000 wide open throttle pulls, etc before the stock valve springs said no more and floated every valve in cyl 1 lol.
A 2007 mazdaspeed 6 with a built motor and big turbo that I parted out during covid
A 2013 mazdaspeed 3 with a bnrs4 bolt on turbo upgrade and tune.
And a 2010 mazda 3 2.5 W/ 6spd.
Needless to say, the cx70 is a big change, but fits my lifestyle now.
Initial impressions:
-mazda has come a long way in interior fit/finish/quality since 2013
-the thing handles great for its size
-the inline 6 makes beautiful sounds and is smooth
-its obvious to that the majority of cx90/70 buyers aren't car people and mostly see vehicles as appliances...but the way this car shifts (I'm assuming it has the latest software updates) doesnt seem out of the ordinary. Under normal acceleration, it is getting into 3rd gear by the time you hit 20mph...but its a short ratio transmission and when driving around normally there isn't a need to rev out further between shifts. Its also quite obvious that the majority of folks have no clue the difference between how a tq converter, wet clutch, cvt, ecvt, or dsg operate. Yeah, take off from a stop can be improved in that the 0-10mph acceleration is probably worst in class because of how Mazda has programmed 1st gear takeoff. But I imagine they are being ultra conservative with tq limits and how much they allow the clutch to slip on takeoff due to it being a brand new transmission they've never used outside of these few models the past few years.
Anyways, I'll update as I put miles on it and get to know it more!
Welcome back and congratulations @bigsho! Fantastic intro, love the perspective of a past Mazda/Mazdaspeed owner and awesome to see it accompanied with a bunch of fun pics...Cool color choice as well...I'm looking forward to your updates..(y)
Just under 900 miles so far. Avg Mpg readout on the dash is 28.9mpg (I reset it leaving the dealership). Keep in mind, this is probably 70-80% highway miles and typically at 75-80mph. I'm sure the estimate is optimistic by 2-3 mpg as all of my previous mazdas have always shown 2-3mpg higher than the actual hand calculation of miles driven ÷ gallons filled.
I did get a couple phantom blind spot notifications on the passenger side today during sunset time,Which was interesting but only would last 2-3 seconds at a time and then go back to normal operation.
I havent made up my mind if I prefer driving with i-stop on or off. It doesnt seem to bother me much, but as a car guy...I worry about long term effects of the engine firing up and shutting down like it does. Although I will say its pretty cool how Mazda chose to fire the engine back up via combustion and not starter or the hybrid system.
The headlights are fantastic. The newest vehicle ive personally owned prior to this was the 2013 MS3. While it had the HID's with AFS, the output was garbage compared to these new LED setups. I can actually see well at night now!
The main cup holders in the front dash area are tiny. My better half can't fit her ridiculous Stanley cups in them, and while that doesnt bother me...she does not like it nor the small center console. The small center console also doesnt bother me as I dont really keep stuff in my car aside from necessities and when it comes to drinks...its either coffee or bottled water for me; which fit fine.
The driving dynamics for a nearly 5000lb, 200" long vehicle are fantastic. It doesnt feel as big as it is on the road, and handles sweeping highway on ramps at speed as well as twisty back roads no issue for its size as long as you're aware you can't drive it like a miata. You get enough feedback through the chassis, and the steering is on the nose.
Minor annoyances:
Thursday, I had a road trip for work. Figuring out the total mileage round trip, I knew if I went right to the gas station and headed out on a full tank, I wouldnt have to stop for gas the rest of the day. So here's where it gets weird. I had 1 tick over 3/4 tank on the fuel gauge when I pulled in. Figured a quick few quick gallons to full and I'd be on my way. Wrong. Pump would shut off immediately when trying to gas up. Maybe its the pump? Moved to another one, same deal. Ok...weird on a brand new car. So just in case, I drove down the road a bit aggressively to burn off some fuel, got it to 3/4 tank on the nose on the gauge, went back to the original pump and it filled up fine. Tried again this afternoon at a different gas station. It will not take any fuel from a pump if theres over 3/4 tank full. Not a huge deal, but annoying.
Mazdas seat belt alarms....
My fiance and I always wear our seatbelts. No biggie. But we have 3 dogs that love to go on car rides, and prefer to be in the back seat versus the cargo area. Fine and dandy, we have a flat bottom hammock for the back seat. However, with them back there...you have to buckle all 3 belts unless you want to hear the damn seat belt chime go off 80 times before it shuts up. Our previous toyota, we could turn the seat belt alarms off with the Carista obd2 dongle and their app. No such luck with this car. What I'll probably do is buy 3 seatbelt extenders for the back seats so we dont have to remember to buckle all 3 seats any time the dogs are with us.
The heated seats...holy smokes do they get hot on the highest level. Lol.
Anywho, I'll probably do an oil change on my own using a mazda genuine filter and use whatever quality 0w20 find soon just to see if there are any break in materials/metal floating around in the pan/filter. And I'll be doing 5k oil change intervals beyond that first change. Ill let the dealership handle the first 3 5k changes since those are "free".
Things to do eventually:
-order the Turbo S inner tail lamp housings that are on the liftgate so I have fully illuminated rear lights and not just the corners. Kind of dumb to me Mazda only does the fully illuminated tails on the Turbo S models in the US.
-Order all weather floor mats
-order window visors/rain guards
-tint the front windows
-black out all the chrome rear badges
-get a tinted overlay for the big front Mazda logo
Edit:
I forgot this car was equipped with the digital rearview mirror until I saw the little switch on the bottom of the mirror that you'd usually flip at night to avoid glare if you dont have auto dimming. Forgetting that, I flipped the little lever the other day and to my surprise...boom camera rear view. It took a few minutes for my eyes to adjust to it but it works real well in daylight. I'll probably only use the DRVM when we have the vehicle loaded up with the dogs and luggage for road trips as itll be nice to be able to load up the cargo area and not have to worry about blocking the rear window and not being able to see out the back. And also, the camera has a nice wide angle that helps see vehicles in your blind spot as they start to pass you or you pass them.
More to come!
Lovin' the updates and pics @bigsho! I see you still have only your MS3 listed under your avatar...If you'd like to update your vehicle info, I recommend using "Custom Title", it shows up in a cleaner and more visible way...To access, simply click on your username (at the top) and then Account details...😁
First oil change today at 2650 miles. I intended on doing it at 1k, but didn't have time before or during our road trip.
Got a mazda OEM filter from the dealership, and used mobil1 dexos 0w20. Will let the dealership do the only free oil change i get at 8500 miles, then will do em on my own every 5k going forward.
Oil change was super straight forward. Spark plugs for the rear 2 cylinders will be fun to get to when that time comes.
So you used the "back on to the ramp" method. That air dam in back of the front wheels is a real pain. Looks like harbor freight ramps. Here is my CX90 a couple of months ago 1st oil change. Found out the hard way the after market oil filters leak so stick with the OEM. Unfortunately that cross member is not in a convenient location. Makes for a messy oil filter removal. There is a lot of info on the CX90 that can be carried over to the CX70. Here are two videos done a couple of months back I found interesting. This guy does a lot of videos on the CX90/70 and other Mazdas .
Here is mine. When did you get yours?
Good to see a DIYer. Like the color. Don't think you can get a CX90 in that color.
So you used the "back on to the ramp" method. That air dam in back of the front wheels is a real pain. Looks like harbor freight ramps. Here is my CX90 a couple of months ago 1st oil change. Found out the hard way the after market oil filters leak so stick with the OEM. Unfortunately that cross member is not in a convenient location. Makes for a messy oil filter removal. There is a lot of info on the CX90 forums that can be carried over to the CX70. Here are two videos done a couple of months back I found interesting. This guy does a lot of videos on the CX90/70 and other Mazda's.
Yeah, I had read about some of the other oil filters not sealing properly. So went with OEM mazda and will continue to do so.
Picked it up just a few weeks ago on Memorial Day. And yep, Zircon Sand Metallic is not available on the 90 as of now. Just the 70
Welcome back and congrats on the new CX-70! Thanks for posting the very insightful write-ups and videos, I know that they will help other members who may be considering the CX-70/CX-90. I do have to admit that at first glance of your username, my first thought was of a Taurus. ;)
Also, thanks for sharing some pics of your previous rides. I always loved the MS6! It had its quirks but it was one good looking beast while blending in to the sea of other four door sedans on the road at the time.
I'll be doing the first oil change on our daughters CX-70 PHEV PP in the next couple of weeks so I appreciate the pics you posted and the video that @RobertJT posted. They gave me good visuals of what I'm about to get myself into. lol I already bought an OEM filter from the dealer along with some Ow20 so now I just have to coordinate with her schedule. I'm still on the fence about buying a Fumoto valve for it. I have one on my MX-5 and love it for the ease of use and no mess (when draining the pan at least).
I look forward to seeing/hearing more of your adventures!
Appreciate it!
I've always wanted a Taurus SHO so I could get a vanity plate that says SHOS SHO...LOL. If I ever end up getting one, it'd be a first gen with a 5 spd 🙃
I've thought about the fumoto valve for this as its the first vehicle ive had where the undertray actually fully covers the oil pan, and also this is also the first vehicle in over 13 years that ive had that isn't lowered and has decent ground clearance to where im not worried about hitting something on the road and ending up with no oil, haha.
Will keep adding insights and also updating the YouTube channel as I go!
Love the vanity plate idea! I've always had a preference for the 2nd gen body style do to the front end. To me the elongated head lights with less amber look so nice and clean.
My Miata is the first car I've used the Fumoto on and I did have some concerns but I went with the one with the adjustable drain valve. Not to mention the ND chassis has a cover similar to the CX-70/CX-90 (but held on with bolts vs plastic rivets). For the ND, this cover also functions as a stressed member of the frame.
Nice find on the mats. I look forward to your review on them so I can feel like a 🍭 for buying the OEM all-weather mats for our daughter.
Another quick road trip last night. Continually impressed by the gas mileage this thing gets...
Heat wave this weekend into next week, so I dont know how much I'll be going out. Stay cool out there!
5500+ miles now...
Still loving it and the vehicle has been trouble free so far (aside from a nail in a tire already).
We're in the process of relocating out of state, so have been making a lot of trips with the back loaded up to our storage unit while we got our house ready to put up for sale.
Something interesting to note (I can't attach csv files here without hosting them elsewhere first)...we already know mazda has underrated the power/tq output on these as on a dyno, they're putting out near advertised hp at the wheels and more torque than advertised at the wheels. Being the curious guy I am, I started data logging some stuff on 87 octane and also on premium 93.
I know mazda only advertises a power difference between regular and premium on the Turbo S models, however on my "low output" 3.3T on 87, the ecu commands negative or retarded ignition timing til about 4500rpm, 0 advance from 4500-5500, and then jump to 10° advance from 5500 to the limiter. Pretty consistent regardless of ambient temp being 70 or 100. On 93, itll retard ignition timing for spool up, however from basically 4800rpm up, its advancing timing....which should theoretically result with more power up top. Unfortunately my Bluetooth obd2 dongle is slooww, so with even only logging rpm,speed,boost,afr,timing advance...the resolution is low. At some point id like to get a wired adapter and see if I can get solid data logs with more PID's logged to compare and see if theres a legitimate power difference.
@bigsho First of all, great updates...You mentioned CSV files...I've added it to the attachment list so you should be able to upload CSV files now...Not sure if it will work/work smoothly but please give it a try!
Also love that you're digging into the engine data and with one of Mazda's new engines/platforms, very interesting! This could be a topic worthy of its own thread in our CX-70/90 Powertrain Sub-Forum :love:
Here's a log of a 0-100 run on 93 octane. Could only log a few parameters as adding any more gives you even worse resolution with the Bluetooth dongle i have.
No brake boost, 100° ambient with high humidity.
Once I have some spare time, I'll get a better obd2 adapter with faster data transmission and do logs on the same day same road, but with 87 vs 93 to be able to compare actual data and with more PID's.
My major takeaways from the attached log:
-Mazda is still using the same approach as they did on the MZRDISI (le sigh), running super rich up top. I get these are high compression, but there is zero reason to be running 9-10 AFR up top.
-ignition timing is only negative (retarded) during shifts and initially when I went from 0 throttle to wot, to start making boost towards the top of 1st gear,and to spool the turbo back up to hit load/boost target after the shift from 4th to 5th gear. This is not the case on 87 octane
-this thing (the i6 engine/turbo) if used in the next gen Supra (rumors floating around), should be capable of making some good power. Looking at the size of the Turbo, its barely getting into its efficiency range on the factory mapping on either the low output or turbo s variants. I wouldnt be surprised if it can run 30-32psi reliably. Toyota will just need to figure out a good transmission option for it.
More to come down the road...
And just incase you dont have excel/sheets to open the csv, ive attached a screen shot of the log. Granted, its long, so im sure the resolution will look like crap when expanded (yellow rows indicate a gear shift event)
