Ill pop off a few pictures for you so you can see ride height and stance.
Hes rollin stock MP3 wheels.
Potholes are fine on the 3 setting, on 5 road moguls and potholes own you, but I havent bottomed out on it since the install (I drive the car quite a bit, generally once a day or so).
No rubbing, no clearance issues, the rear and front both seem to sit good, its definately lower, it seemed to increase the response of the steering wheel (more direct input from the road it seems) and the overall feel of the car is more crisp and direct.
Install took us a few hours. Do yourself a favor and pb blast the hell out of your sway bar endlinks where the attach to the strut mount point. The fronts are especially a PITA to get off, we had to use a torch and vicegrips on one of his, it was SIEZED.
Do yourself another favor and get a buddy to help you, Its almost impossible to get that center nut over the strut mount tightened without help. I found I couldnt get it tightened down all the way unless I actually held something on the center bar that the spring goes around (get yourself a bicycle tube or something you can wrap around there and hit with a pair of vice grips to hold it in place while your buddy tightens that bolt. Whatever you protect the metal with needs to be thick enough to keep the vice grips from biting into the metal, else your warranty on the tokicos is no good.
Clearance on the rears is somewhat an issue but you can get to the knuckle to strut bolts on the bottom without removing the brakes.
Apparently on the front struts there is a "wrong" way to mount the strut mount top, so pay attention to how it comes off and how you put it on, otherwise your alignment shop may not be able to get the camber out of that side.
And again, pb blast your sway bar endlinks the night before you plan on doing this, and again 10 minutes before you plan on removing them.
Oh one more thing, it may seem that you have to, but you dont need to remove the battery holddown, or the strut brace in the front.
Thats about all I can think of, if you have specific questions let me know, otherwise it was a pretty straghtforward install.
Oh, another piece of advice, get some antisieze compound for your swaybar endlinks and apply it. It makes putting them on easier and also makes for easier removal next time they have to come off.
