so i have new spark plugs 1 step colder , new oem wastegate , new 1st o2 sensor, fmic and just checked and there is no boost leak, when i installled the new wastegate i replaced the turbo exhaust gasket and the exhuast manifold gasket. i have catless corksport exhaust and a secondary o2 bung adapter for the cat delete. i also have a SSAFC . a wideband , oil pressure, and a boost guage.
the turbo builds boost fast and holds it well, no abnormal noises during acceleration or idle .if i hit WOT at low rpms and build it up its slow and the afr's go right down to 10. but most of the time if i get to about 3000 rpms without boosting it seems like it has much morer power.
also this power loss issue has becaome more frequent since i replaced my wastegate. i consider it an intermiddant problem so im curious if it is something simple like coil packs or electrical, or would it be a part of the fuel system? i know if it was a boost leak or if it was a mechanical issue it would happen all of the time.
i do not have a vtcs delete and it got me thinking so i revved the engine up whle i was under the hood and noticed that the actuator arm for the vtcs does not budge. might be associated to a hidden cel for p0660
please help im getting desprete with this damn car lol
