It's not hard at all. It makes it hard when you don't know where the sweet spot is. See when I first got the valve it seemed like it was adjusted pretty well, but then one day I tightened it up to see what the difference was and noticed a bit of hesitation between shifts went away.
I think what everyone is trying to do on here, is really to find that sweet spot for optimum performance. Any monkey can twist the top to "adjust" it, but how do you know when you have it just right? Plus it doesn't help that you can't notice the difference immediately, Turbosmart says it takes up to two weeks to 'fully' adjust.
I seen somewhere it says that with partial throtle release you should get a valve flutter. Is that true? Mine doesn't, so does that mean mine is set too soft? Either case I'm holding a healthy 16psi through the gears, hitting 17-18 in fifth. Any good suggestions?
