Seafoam / Engine flush
zhy
I aint even mad!
Just wondering, im buying a p5 this week and I want to clean the engine first of all.
I tried searching for a complete how-to seafoam of our car, but without success
would I be better off with the seafoam or the engine flush OR both? (shrug)
Neither?
Engine "flushes" often do more harm than good, just use a good quality oil and change it frequently. I change mine roughly every 4-5K Km, but that's because I don't drive too much and do mostly city driving.
I don't think seafoaming your engine can do any harm, but I don't believe it'll do much good either. Unless the throttle body looks gummed-up I wouldn't bother. I did it just for kicks and didn't notice any difference, the white smoke was certainly entertaining but I wouldn't do it again. Most people do it by pouring the seafoam into the brake booster vacuum line while holding the throttle open a bit to prevent the car from stalling. Read the instructions on the can, the procedure is pretty straightforward.
Find out if the car still has the original ignition system, if not I'd recommend replacing the ignition coils, the spark plugs and the spark plug wires as preventative maintenance (perhaps you can use this as a bargaining chip). If any of those components starts to fail the engine will run rough (and even stall) and eventually failure to replace these parts will result in rapid deterioration of the primary catalytic converter which is a b**** to replace and is pretty expensive.
Also, if the engine has a rough idle which isn't related to a faulty ignition system the EGR valve might be stuck open/closed. These cars are notorious for going through EGR valves, especially in our climate. Mazda has a revised valve which is supposed to last much longer, often referred to as the "Canadian EGR".
Other than that these cars are pretty good (if you can deal with the rust), good luck on your purchase.
ive used it on all my cars including the p5. the car felt better just pouring the whole bottle int he fuel than doing the whole brake booster ad in oil bit. if you do follow through with the brake booster and oil bit, remember to change your spark plugs right after. if not, itll have a purple kind of stain on it that may ruin the plug. usually, if i need to change my pcv valve, oil, oil filter, and spark plugs ill seafoam if i have the extra cash on me.
I've seafoamed 3 proteges and all have felt smoother. i actually do it the correct way as well( oil feul and pcv )
I usualy had about 1000 miles on the oil when doing it then drive it no more than 50 miles after. and then i changed the oil....
nothing happends to the sparkplugs or pcv vaulve.
though 2 times i've had the check engine light go on... all i did was disconnect the battery for 10min. and reteach the ecu.
simple as that.
i would recomend doing it.
i wouldn't recommend doing any 'flush'.
if you want, pm me and i can help you out in more detail
simple as that.
this man is correct, SeaFoam in particular as long as you follow the directions is not going to harm your engine, it will enhance your engine. i just seafoamed my civic and you don't feel 50 more HP it just feels much smoother as he says
http://www.seafoamsales.com/how-to-use-sea-foam-motor-treatment.html
The thing is, if you know what your doing, you have nothing to lose.
i thought my car was fine... but sure enough it got smoother.....
not newcar smooth, just smoother
ofcourse if its going to make it run smoother, 10$ isnt a ton on money
im def going to do this
Use the brake booster vac line. If you add it to the oil, as said change the oil soon after. If you use the pcv valve line you won't clean as much of the system as this doesn't feed into as large of an area.
I just did the flush on the wife's P5. I added 1/3 to the brake booster, 1/3 to the oil, and 1/3 to the gas. The car already runs smoother and quieter. I'll have the wife take the car in for an oil change at the end of the week. Normally I do all my own oil changes but I want her to take it in 1. because I am in the middle of rebuilding our master shower from scratch 2. Since I've owned it it's never been into a shop and I'd like to get a once over from the pro's.
thanks for all the replies
so 1/3 in the brake booster
1/3 into the oil
1/3 into gas tank
go drive 20-30 km's, change oil to fully synthetic
if it has higher miles use conventional my car aparently hates having synthetic in it and will burn a qt every 1000 miles or so
New Threads
