shane02pro5
25ish_psi
- New Caney TX
High rpms the butterflies close...without them flow will be screwed!
next week ill be driving to canada for 7 hours and ill monitor my speed and will see what i get. i have smaller tires on now than stock so it will say i went more miles than i actually did. do you still have your stock air intake including that plastic crap that went on top of the radiator??I'm pullin 31-32mpg doing 67mph on my 30 mile each way commuting to and from work in sportauto using AC all the time. Still running without VTCS and the VICS that was red loctited has had no issues. The new 2012 Elantra that is rated 29 city/40 hwy isn't even pulling those numbers yet. Hoping it does after break-in period tho.
Oh yeah, I hang on to all that stuff............
They do have a 5 dr hatch...Elantra Touring. They are also coming out with a new 5 dr hatch...i30 or something like that. Then there is this 3 dr hatch called Veloster that I think is supposed to be coming out this fall..........i12drive,
Thanks for the link. I've seen a few around. It's a great looking ride, particularly in black.
Too bad no hatch.
Elantra & new Focus have caught my attention. Hope I can get another yr out of the P5,
I know I have to start looking.
Thanks.
No, all that mess is in a box in the attic.do you have it still on the car i mean. are you using it?
This was a recall. I remember getting the letter. They swapped mine out while car was in shop for hit and run incident and it was after I had already done the VTCS removal so I have the unmolested recall intake they put on it on my workbench. I actually had another extra intake that I did the VTCS removal on a 2nd time after getting the car back.mazda should be able to check the vin record to see if the recall was done. (if it was a recall - i thought it was only a TSB?)
