Saving fuel on CX9
denot
Hi all,
Anyone know what mod can be done to reduce fuel consumption on the CX9?
My 3mnths old is currently doing 20L/100kms (or 11.76MPG) which has been done on 99% city driving.
Thanks for the help.
Denot
That's unfortunately about right for all city driving. Horrible, isn't it?
Apart from reducing weight (don't carry stuff you don't need), you're stuck. I've tried changing my driving style with the car (i.e. nice and easy acceleration, rarely mashing down the pedal), and didn't see much of an improvement. Look up "hypermiling" on the internet to get all kinds of tips, some of them wacky, but in all honesty they won't matter that much. This car is a heavy beast, and the beast likes gas. I don't think you'd find anything much more efficient in that same weight class, apart from a hybrid.
Best way is to change driving habits as much as possible. Most of the crap you see out there that claims to increase is just that....crap.
The oem holes in the bottom of the airbox, I drilled them larger, much larger. Put a K & N drop-in filter in, and have tried running my z-rated (low drag) tires around 40psi, removed the oem hitch, and all that does next to nothing to improve mpg.
91/92/93 octane might improve fuel economy....anyone tried that?
Good grief! It looks like I better ask "How can I improve the performance of my CX9" rather than looking to find a way to improve fuel consumption rate. :(
The issue is doing short trips on cold engine.
Due to emission concern, engine runs rich to heat up CAT. That kills MPG on cold engine.
I drove a '07 Ford Escape AWD hybrid for 4 years and applied hypermiling techniques yielding respectable MPGs. The gains were in city driving using a scan gauge to monitor battery charge and stay in battery mode as much as possible. Using pulse and glide so regen brakes could maintain charge. I moved out of the city to the rural mountains where 90% of my driving is 60+ MPH so the MPG fell off fast, yielding around 25 MPG so there was no advantage in having a hybrid, plus I exhausted all my tax credits so I sold it.
There isn't much you can do to improve MPG in the CX-9. It's a 5,000 lb boxy vehicle with an old school V-6. The best you can do is keep the load as light possible and try not to start and stop as often. One thing I learned from driving a hybrid is to read traffic better. keep your speed consistent so your not at the traffic lights waiting for it to change and having to start from a dead stop. slow down before the light and coast up to it. Also, invest in a scan gauge as it gives more accurate information than the factory gauges.
I drove my wife's Prius for its first 3 yrs (yes, for the HOV access) to save commute time by 15 minutes each day.
I learnt all the pulse-n-glide also.
Timing the red lights is probably the most effective way to cut down MPG on city driving.
Each acceleration gives you 5-7 mpg. (Scangauge shows that clearly)
Also, idling on red lights hurts MPG also.
Plan more right-turns than left turns whenever possible if distances are similar.
Try to maintain at 42mph+ when CX9's transmission puts you at 6th gear to cruise.
Denot - where are you located? Australia? What are the temps like?
On a Honda Pilot forum, I saw someone reporting very poor mileage and it turned out they lived in a cold region and were letting the car idle in the morning to let it warm up. Like Ceric said, the car will run rich while coming up to normal temp. The correct way to warm up a car is to start the engine and drive using easy acceleration.
I doubt this is your issue if you're in Aus, but worth mentioning anyway.
I would expect 91 or higher to result in decreased mileage.
If an engine is designed for 87, using 91 fuel decreases MPG.
The energy content in 91 fuel is less than that of 87 per volume.
Unless you're driving your car like you stole it, there might be something wrong with the car. I live in NYC and spend a good deal of time in stop and go city traffic. In all-city driving I've never gotten less than 16 mpg and on all-highway trips I've gotten as high as 22 mpg. I'm pretty diligent about tracking mpg each time I fill up (although I've found that the trip computer is pretty accurate...never more than .5 mpg too high). Most tanks I get 18-19 mpg in mixed driving.
With the CX-9 (as with any car) your driving style is the single biggest contributor to fuel efficiency. I generally drive pretty casually without much hard acceleration or hard braking. They say that if you drive as if you have a cup of water on the dash you will keep things smooth and steady and maximize efficiency. I usually have my greyhound in the cargo area and she likes to sleep but gets up every time there's a hard stop or other quick maneuver. My trick is to keep her asleep and I think that pays off in fuel efficiency as well.
I get 10mpg or less bus-ing my kids to schools 2 miles away and back every morning.
It is not even cold in California.
On highways, I can get 21-22mpg w/o trying hard.
If you're getting 16 mpg in all-city driving, then something is wrong with YOUR car! We get about 16 in mixed driving, and maybe 22 on the highway. I think my wife had once calculated something like 12 mpg during a week where she had to drive in town a lot, red light to red light, that's what I call all-city driving.
I'm not that upset about the mpg, even minivans get bad mileage.
All this talk of gas milege makes me even more thankful my commute is about a mile and a half :)
Even in my 5.4l F150 I can usually go a month between fillups. Wifey works from her home office, so no commute there, but she does all her running around in the 9. Probably close to 2 tanks a month for her.
Ok just fill him (yes my car is a "He") up today, and the meter on the car said "15.2L/100kms" (15.48MPG), but when I calculate manually, its actually 16.8L/100kms (14MPG) this is due to me driving on a motorway on the weekend (almost no traffic at all).
Not sure how you "manage" your footing, but releasing the brake and touch the pedal a bit already give me 40L/100kms (4.88MPG) on the meter, and as you need to speed up from 10km/h, it builds to 99.9L/100kms (max reading on the meter - 2.35MPG) and then down to around 30L/100kms (7.84MPG - after change gear). Then after I release the pedal and hold on the current speed, it goes down to 11-15ish (21-15MPG).
Oh and Note: my comute is around 30kms (18.64Miles) a day on almost 90% bumper to bumper and full of red light traffic. And have to go around and climb up and down a big hill for a few times a day to find a parking spot.
^denot
There isn't much you can do on reducing the fuel consumption of your 9. Stop & go traffic, especially combined with climbing hills will kill fuel consumption on every car. You could trade your car to a prius if you want better fuel consumption :p just kidding :D
New Threads
