ive wondered about cryo treating my internals, i dont know if anyone on here has done it, but if youre opening the engine its WAY less money than forged internals. the question is how effective it is.
K1's are great for what most people do to the protege. Pauter is kinda overkill IMHO hahaha. But if you want to pay the big bucks for them im not going to stop ya. haha The K1's are rated for about 350+ HP, and I HIGHLY doubt anyone (well 99% of you) will ever go that high. K1's are great for the price and they dont have really any issues at all.
If you get the K1 long rods with Wiseco pistons it Improves rod ratio from 1.467 to 1.491, A higher rod ratio cause the pistons move from TDC slower, the entire bottom end absorbs less mechanical stress. Which is a GOOD thingBut IDK how much HP the longrods can handle.
Some points you stated need to be corrected for those wishing to have something more than a thrown together motor.I only rehoned the cylinder walls. As for balancing, inline 4 balance is different than v6 or v8 that requires bob weight. inline 4 crankshaft is balanced alone with flywheel and pressureplate + crank pulley. without piston and rod attached. so if you ever removed a stock crank you will see theres drilled hole on counter weights. that means its already balanced at factory. as for piston and rod, they must weight all same. so when 2 piston go up and 2 go down the harmonic imbalance cancel each other. Wiseco and K1 rod are all factory weight matched to +/- 1gram, which is better than stock stuff.
I check the stock piston and rod assem, its +/- 3g off... but they are lighter than forged part. Unless you rev your engine to 8000+rpm, theres no need to balance the crank asembly
I think it was something do to him running a Microtech. I read where JDM Sam had a similar tuning issue where he discovered something with the Microtech tuning interface.Just be careful on the whole long rods thing, the stress applied to the bottom end will stay the same, but the horizontal "stress" applied to the sides of the cylinder walls will be reduced because the angle is changed. Also because the long rods spend more time at TDC and take longer to move away from TDC, there might be more chance for detonation.... Kicker22705 was pinging at 11psi with long rods, and he was running a standalone.
