RX-7 Amp wiring?
AznXstazy
Mazda MP3
hey guys, im posting for my cuzins rx-7 turboII. he wants to wire a amp in there, but i took a look in his engine bay. looks like no where to run a amp 2 gauge wire in there. its a big wire.... cuz hes planin on running 2000watt worth of subs lol. we're not lookin into drillin any holes. firewall to thick and would have to much problems doing so. well anyone comment on where he could run the wire through?
The FW isn't that thick. Not any thicker than any other FW anyway. Where else would you run it? You could run it underneath, then you'd still have to drill a hole, but this time in the floor board.
If you wanted to do it the hard way you could run the wire through plastic conduit along the bottom of the car. There should be a rubber grommet in the bottom of the spare tire well. IMO just run it through the car. If you have to drill a hole just use a rubber grommet from your local parts shop, It will look factory, keep water out, and protect the wire. Drilling holes is fine as long as its done right.
yea i mean the firewall is where im trin to go through. im just wonderin is there any holes that i could "share" with other wires or something. example, my freinds 88 supra he found a hole that was plugged by a rubber bushin. we took it out and found some wires and they all went through. anyone know if theres somewhere we could "share" wires.
