Rust inside the fog light?
clicknext
2006 Tungsten Grey Mazda6 GT I4
There seems to be rust on the inside of my fog light, behind the glass on the metal part.
Anyone run into this and/or know a good way to fix it?
Thanks!
yuck, i would guess that since you cant open them up, you'll have to replace it.
I also have this problem.
I'm led to believe that RING do a fog light which fits in this space exactly, for about 20% less than Mazda want for one light!!!
Or, you can do what I'm doing and fit fog light delete trims from Street unit. :D
I would think the only option would be buy a new light... but then you would probably wanna buy the set cuz one new and one old will not match. Or like geetee said go with the deletes and ditch the fogs all together
id say stay with the fogs and just go get a replacement, look for one or a pair in the f/s section
Thanks!
Yeah, take the light off the car. Take the light apart. It does come apart. Find out where it's leaking. Clean it. Seal it. Put it back together. Go more. OK, looked at pic. Find spare(s) in FS section.
