in neutral, when i press the brakes i get a raise in about 400 rpm. any ideas?
The increases in RPM is because the break booster / master cylinder is run off of vacuum, and needs the extra RPM to complete the load cycle. Much like if you turn your AC on you will notice the RPM increases also do to the extra load placed on the motor.
