RP help and opinionsplease!
jlocurto
2008.5 Black Mica Mazdaspeed3 Grand Touring 7/15/08
what racepipe has everyone been going with? is there a difference between the power gains from them?
no theres no difference they are all just a piece of 3'' tubing thats the same but made by someone else. go with whatever company you like. Corksport is a nice one
I also like the corksport, but again, I own their downpipe and racepipe ;) Like everyone says, its just pipe, some with a teeny bend. If it's cheap, go have a muffler show weld flanges onto scrap pipe. Honestly, you will get the same performance. Now, if you did that with a downpipe it would be much different ;)
Shouldn't be, some are straight and some are almost straight pipe. Power, sound, flow, etc should be the same for them all
just have your local muffler shop weld a piece of pipe where the cat is on your mid pipe for like 30-$40 and you will get the same power gains as teh expensive ones. thats what i did until i finally made my own with stainless 3''. I would do that and then spend your saved money on an intake or DP. good luck
Here is a video after installing mine, its a Protege Garage 3-inch pipe:
http://www.youtube.com/watch?v=Uy8Trr7l_Sg
In the video I also have my 2 resonators and muffler cut out and straight piping welded in there, thats's why its louder. But its MUCH louder in person that the video suggests. Sounds like a boggy/gargly wrx the way its been modded right now.
My friend installed his in the driveway at the same time and put a Turbo XS on there. They all work the same. All are made about the same. Corksport ones look nice but you may have to wait until the end of the year to get them as most places are out of stock. No need for hangars really.
Sound difference should be the same with all same with performance.
I tried havign a muffler shop cut the stock cat out and weld in straight pipe but living in CA they will not do it since it illegal to remove the cat.
damn! the corksport rp is on backorder too?! thats the one i was looking on getting while waitin for my cobb sri to get off back order!
