im researching the Rotella T6 too, so far i've seen nothing but gushing reviews for it here and on Bob Is The Oil Guy. T6 is fully synthetic, T5 is synthetic blend. in many cases where T6 is recommended, T5 also meets the same recommendations. in my mind, motor oil is motor oil...whatever's in the bottle (and on sale) will do the job.
i already knew that the differences in brands mostly lied in the additive packages. what i did not know was the 40 oils burn off slower than the 30, and that when they burn off the additives don't last as long and aren't as affective.
so at the advice of theMAN, because i'm still troubleshooting why my car consuming massive amounts of oil, i will switch to a 40 weight oil at my next oil change, and the 5w-40 Rotella T6 seems to be available at the local big box stores cheaper than Mobile 1, Castrol SYNTEC, Redline, AMSOil, and Royal P.
Mobile 1 also makes a heavy duty turbo diesel product that is comparable in price to the Shell Rotella T6 but i have not seen it on the shelves locally. both are API SM certified for gasoline engines.
