Rotation time!
BlackJack
2007 Mazdaspeed3 GT (gone :()
I've got two big road trips ahead of me (6 hours and then 11 hours) and I keep noticing that the front tires has shorter threads than the back. I'm thinking if I rotate the tires, will it handle a bit better?
If so, what's the way to rotate the tires? Just swap the front and back wheels?
front to back, thats how the book says so.thought id post this to help people out as recently wev had quite a few people having problems with bios
all the beep codes are different depending of who makes the bios , but here are some of the more common ones
What is a BIOS Beep Code?
When you power on a computer the BIOS immediately takes control of the computer and performs the P.O.S.T (Power On Self Test). At the end of the POST the computer will play an audible 'BEEP' through either the PC's internal speaker of through speakers attached to the sound card (if you have a built-in sound chip). If the POST completed successfully without detecting any problems with then system will play a single short beep to let you know the test is complete and the computer will continue to startup and load the operating system.
If during the POST the BIOS detects a problem it will normally display a visual error message on the monitor explaining what the problem is. However, if a problem is detected before the BIOS initializes the video card, or a video card is not present or not detected then the BIOS will play several 'BEEPS' through the speaker to let you know there is a problem. Depending on the type of the BIOS you have the BIOS may play beeps in a specific pattern to indicate what the problem is, or play the same beep a number of times indicating the problem. It is very important that you pay close attention to the number and/or pattern of the beeps your computer plays on startup.
Below is a table of the most common AMI, Phoenix and Award BIOS beep codes.
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video cardthought id post this to help people out as recently wev had quite a few people having problems with bios
my fronts were running way too low and after rotating them i definitely felt a difference, and i chirped the wheels less too
This is straight form the manual.
I'm at 11000 miles now so I think it's safe to say that the stockers are damn good s***.
yea, dealership is trying to charge me to rotate it ..i think 40 bucks, cuz it's an hour to rotate the tires they said... so they rounded it of to an hour rate..i said bulls***, it only take 15 minutes.... but they are not buying it, they said they want to take their time to carefully rotate them.. dealerships are a b**** !!!
is there another way to safely rotate them myself... i have 2 jacks at home...but i dont want to put pressure on my left suspension when i lift up the right one.... will this work ???
LOL an HOUR to rotate your tires?!?! I could get all the tires off myself in 8 minutes. If you don't have a torque wench i would get one so you can torque the wheels back on. Other than that you have all you need.
1. Loosen all lug nuts
2. Make sure the E-Brake is on and jack up one side of the car.
3. switch the wheels on that side and set it down.
4. jack up other side
5. switch wheels on that side, set it down
6. Torque the lug nuts.
Don't even have to use jackstands. You can if you dont trust your jack though. Thats such an easy job don't take it to the dealer for that simple stuff.
What about the tire pressure monitoring? The damn manual takes 2 or 3 pages warning you about it. No special concerns as long as the tire isn't coming off the wheel?
The way I do it is I use one jack.
Do one side at a time.
Take off rear, install spare.
Take off front, install tire that came off rear.
Remove spare and install tire that came off front.
Rinse and repeat.
not 100% sure but i think you have to reset the TPMS after the tire rotate or else the lights gonna go on. my shop charges 4/10th's of an hour and a 5/10th's to reset the TPMS so an hour at the stealership sounds bout right:(
You can get the front and rear tires off the ground on one side with only one jack. In fact, it's safer/easier than trying to do it with two jacks. Just make sure you are on firm level ground first. Put the jack under the front jack point and crank it up until both wheels on that side are in the air, then switch them.
If this is something you've never done before, ask your friends/family to see if anyone with wrenching experience will help. It is an incredibly simple job and really should only take 15 minutes, but if you've never touched a tool in your life, the experienced helper can keep you from potentially serious mistakes.
24 minutes to rotate tires and 30 minutes to reset TPMS? (nervous) thats whacked....
Flip if they are charging you 40 bucks its most likely not a 1 hr job they are quoting you... here in LA hourly rate at dealer is closer to 80-100 bucks depending on car make - I paid 40 bucks for my rotation cus I didnt have the time to do it on my own - it was effectively a 20-30 minute job and in all reality dealers wont bother charging you less unless you have car in for other stuff at the same time - Im sure if you were doing oil change, tranny service, brake job, etc they would have thrown in the rotation for free... (I got a free car wash with mine)
...Rotating my tires today after work, do i need to worry about resetting the TPMS and how do you do it?
+1
I'm wondering this too. Is there a special rigamarole for the TPMS when you rotate tires, or do you just not worry about it?
