Rota Actions
azeli73
Contributor
2002 Protege 5 Turbo
I got a co-worker that wants to sell his Rota Actions in 17" x 7.5", 5x100 bolt pattern, 48mm offset, & 56.1 center bore. This won't work for a protege5 because of the 5x100's right?
hey azeli, how much are they going for? i have a neighbor with a jetta that this might fit. i just need to research the offset and we're in business.
tonkabui - the Rota Actions made for the Subaru is a 17x7.5" wheel +48mm offset, 56.1CB. It will fit the Jetta in terms of bolt pattern, however the CB is too small. So the CB may need to be bored out to run those wheels. As for offset, add a 10mm spacer and run 225/40/18 or 225/35/18 depending on year of Jetta
